continuous input and finite output in "Multi function AO AI sync.vi"
 Hello everyone,
Can I acquire data continuously and output finite number of data with "Multi function AO AI sync.vi"?
Thanks for your help!
(2,713 Views)
Accepted by Xiang00
I think this should be possible.
Just change the sample mode of your genearting samles path to "finite samles" and add a constant or control with the number of samples you want to generate..
regards,
adigator
(2,705 Views)
