continuous square wave for analog output
Is it possible to generate a continous square wave with different amplitude level for analog output by using NI6008?
I do appreciate ur helps and thanksyou.
(3,032 Views)
The USB-6008 allows only software-timed updates to its digital to analog converter (DAC), up to 150 samples per second, so a continuous analog output is “possible,” but it will be limited to slow update rates and the timing will not be as accurate as a card capable of hardware timed analog outputs.
For a LabVIEW example of software-timed analog output, please see the "Gen Mult Volt Updates-SW Timed.vi" example, available in the LabVIEW example finder (Help»Find Examples»Hardware Input and Output»DAQmx»Analog Generation»Voltage).
Another example can be found at the following link:
Continuous Software Timed Analog Output for the USB-6008 and USB-6009
You could modify these examples to output a square wave instead of sine wave and place a control on the front panel to change the amplitude on the fly.  The amplitude control should be placed inside of the while loop.
Jared T.
(3,017 Views)
Thanks alot for ur help and i do appreciate it, i will give it a try. Thanks
(3,006 Views)
