control TTi TG5011A-B Pulse Generator - Pulse Frequency Range Min: 500 uHz
Hello i would like to do a automatic test"generating a pulse signal" with TTi TG5011A-B Pulse Generator - Pulse Frequency Range Min: 500 uHz by a software ,and i would like to know if Labview is compatible with the hardware or not?
(2,883 Views)
this is compatible with labVIEW.
In below link go to "Resource" tab to get labview drivers.
https://www.aimtti.com/product-category/function-generators/aim-tg251xa-501xaseries
Suggestion:Before using the instruments go through the user manual/programming manual where most of your questions are answered.
Expand.Evolve.Influence
(2,859 Views)
Hello ,
sorry but i don't know which one to choose, and how  can i control this device by labview?  is there a tutorial or descriptif to help me to do my test.
(2,849 Views)
In the same link which i shared earlier you can find the data sheet in that you can find how to connect instrument to labview,It has LAN/USB/GPIB interface options for remote operation.
If you are new to labview go through labview basics in NI website you will find great learning resource their.
More info:
(2,841 Views)
