control of external device by calculating the values from analog i/p
The external device is started or stopped by calculating the values from continuos analog acquisition. For example: I want to start a stimulator if the input is achieved 10% of its maxmimum. Any help would be appreciated.
(2,434 Views)
If you are capable of continuous acquisition with processing in the loop, you should be able to throw a threshold check in there and trigger your other process. A state machine would work well for that. If you have not worked with state machines in LabVIEW, contact an Alliance Member with LabVIEW expertise. We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,434 Views)
