memory leak with variant/OCX
I'm trying to get images from an IP webcam thanks to an ActiveX and process them with IMAQ.
This ActiveX needs a variant to put chars from the image. It seems to work fine, (nearly 'in real-time') when I convert a string into a variant. Nevertheless, I have memory leak, if I put this sub-VI into a while loop.
So, rather than using a string conversion, I've tried to use a Uchar array conversion. It also seems to work but it is really slow and in this case I don't have any leak of memory !
I'm likely misunderstand the memory managment of Labview.
Thank you very much for your help.
Message 1 of 9
(3,614 Views)
Assuming that there isn't a memory leak in the activex object you're accessing (a very real possibility), you are probibly not closing a reference--though there could be something about how you are doing the conversion that is causing the problem. If you post your code I could get a better idea.
In the mean time, you might want to consider getting into the habit of routinely closing any references you open. Sometimes a close isn't required, but attempting to close a reference when the close isn't needed doesn't hurt anything.
Note that if you read a property that returns a reference (or an array of references), or invoke a method that returns a reference, those references definately need to be explicitly closed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(3,614 Views)
I've tried to close the reference but without any success.
The activex object may not work very well, but what I don't understand is that when I'm using an array of UChar, it works but very slowly and when I'm using string, I have memory leak but with "real time".
Hear are the code.
Thank you very much again for your help
Olivier M.
Message 3 of 9
(3,614 Views)
I don't see anything here that should cause a memory leak, but there seems to be a subvi missing. Is this the Uchar version of the one with the leak?
Mike...
LabVIEW Champion
Message 4 of 9
(3,614 Views)
Sorry for the VIs I've sent.
Here are simplified VIs, with comments that illustrate the problem.
I hope this will bring you clearer informations.
Olivier M.
Message 5 of 9
(3,614 Views)
On a bazaar remote chance, wire the data from your variant to data functions to the edge of the case structure in SnapAxis.vi. Also can you create a constant of the variant that goes to the variant to data function so we can see the memory leak too. What version of LabVIEW are you using?
Message 6 of 9
(3,614 Views)
Strangeness! Nothing that I can see should be causing your problem, but it looks like you have attracted the attention of Jeremy--which is a good thing. He works for NI and has access to information we don't. I would say follow up with him...
And be sure to let us know what you find.
Mike...
LabVIEW Champion
Message 7 of 9
(3,614 Views)
I'm using Labview v6.1.
I've tried to follow your advice, but without any success.
I've put an indicator after the ActiveX, the variant VImage looks like :
Value -> Array(Non Displayable)
Nevertheless the "variant to data" function enables me to get the pixels.
Here is a capture of memory behaviour during the program run.
Message 8 of 9
(3,614 Views)
OK, I've just received CDs of Labview 7, and now it works very well with Variant to String converter, without any memory leak.
thank you for your help.
Message 9 of 9
(3,614 Views)
