07-27-2009 09:44 PM
Hi to all:
Look, im trying to control my parallel port, but I want to control one by one bit (or pin). I mean I want to have a voltage in pin 2 next this pin wiil have volts and the pin 3 wiill have the 5 volts an so on.
I found the attached llb on the net, but its rare because I have already gorunded the 11 and12 pins of my cable, and when I acctivate a out (pin 2 for example) a read with a multimeter -4.5 volts, so when I deactivate the out there are still 2.20 volts.
So, like I said before its rare, I just one to have 0 or 5 volts.
Also I have no much experience in labview.So, if someone can helpme or explainme will be awesone.
By the way I just readed this one:
http://zone.ni.com/devzone/cda/tut/p/id/3466
And did not help too much.
Thanks!!
07-27-2009 10:42 PM
