control remote application
I made two applications built by LabVIEW and want to press each button in two application.
Two programs communicate  some data via network stream, but I think there is a simple way to press the buttons between (LabVIEW) applications.
(3,483 Views)
Hi labmaster,
what makes you think there "is a simple way"?
Using network connection is a very simple way to have a communication between two programs!
(3,480 Views)
Actually, the network stream is complicated in my code. I mean the connection should be synchronous.
I don't want to control some buttons via this way. Someone provide VI server and functional global but I didn't check it.
Do you have any idea for controlling some buttons on application built by LabVIEW?
(3,477 Views)
