controlling windows media player in labview
Thanks for letting us know.
If you have any questions, then don't hesitate to let us know!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 21
(3,569 Views)
Sorry,
But agin after i do a couple of loops the programm still hangs? After 20 to 25 loops, LabVIEW hangs? Maybe i have to reboot my PC? But at the moment i am recovering a broken hard drive and have to wait for 2 more days before i can restart my PC...
Thijs
Message 12 of 21
(3,565 Views)
I just restarted my PC... but without any luck! The strange thing is that my LabVIEW app allways hangs at the 25th iteration...?
Regards!
Message 13 of 21
(3,558 Views)
Watch your memory with Task Manager while you run the process. You may find you have a memory leak.
Check your processor speed too.
Try running 25 changes really slow  - 1 change per tell you if you have an architecture problem or PC.
It'll give you a better handle on where the problem lies.
(Run with highlight execution on ONLY if you memory usage when running the application after 24 iterations is not > than total RAM available.)
Check you are closing all handles.
(I have not looked at the code - that's just where I would start as standard practice if I had this problem)
Try a different file - does it respond the same way with a larger/smaller media file.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 14 of 21
(3,553 Views)
I allready did that, and the strange thing is that the memory hardly changes, sometimes it goes down a bit... And the processing power also stays stable? I can try other video files, but it is very strange though.
Thijs Boeree
Message 15 of 21
(3,549 Views)
Hell Thijs,
Can you share the last version of this code.
I really would like to see if I'm able to reproduce this behaviour at my side.
Is it possible to share the video-file you're testing with?
Kind Regards,
Message 16 of 21
(3,542 Views)
I've made an update in my k-lite codec pack , i've adjusted the H.264 codec with the libavcodec. Now it seems to go right... But i have do some more tests tomorrow!
Thijs
Message 17 of 21
(3,539 Views)
Accepted by ThijsBoeree
Hello Thijs,
thanks for the update!
I was Out of Office the last week because I was sick.
Have you been able to do some extra tests?
Kind Regards,
Message 18 of 21
(3,526 Views)
It works great!! I've put the k-lite codec pack "on" and i can even scroll trough the movie with an event on "value change". And it's smootly and does'nt hang anymore!
Great!
Thijs
Message 19 of 21
(3,522 Views)
I don't have a "CurrentPosition" option under the "controls" of the WMP invoke node. Does this mean I have an outdated WMP active X driver? If so, how to I get it?
Steve
LabVIEW2009, Windows 7
Message 20 of 21
(3,464 Views)
