controls access through program not proper
VIs developed in LabVIEW 6i has button controls whose T/F boolean values are controlled through program and the control is used as a button as well. When the same VI is run after installing DSC this button control values cannot be changed through the program.
(3,157 Views)
______
Can you please attach a sample VI which exhibits this problem?
Khalid 🙂
______
(3,157 Views)
