how to debug the CIN code?
I just want to make a driver in the LabVIEW for my own device, I had follow the "Using External Code in LabVIEW" manual and maden a empty dll projecte to finish the development. But after I got a .lsb file and put it into my vi,it doesn't work well. There are a messagebox show "0x100012d3" commond call the "0xcccccccc" memory, it couldn't be "written". I don't know what had caused this. Can you tell me? and I want to debug it,but the VC++6.0 ask me to enter the Executable file,but you know the code is for builting a dll,how can I debug it? I eager to get your answer quickly. Thank you very much.The appendix is my main code.
(3,001 Views)
Jacky Wei,
You mention that you used the Using External Code in LabVIEW manual. Check out pages 3-19 through 3-21. They describe exactly what you need to do.
Randy Hoskin
http://www.ni.com/ask
(3,001 Views)
