conversion from hex string to bytes withh out ascii
how to convert hex string to byte numbers without ascii codes,then all the converted bytes should come into a packets
(4,257 Views)
Accepted by rajkumar5
Your question is very ambiguous. Please explain.
Can you give us a Vi containing an example string and what you want out of it. What is the dataype of the "packets"?
(4,236 Views)
What people consider ASCII and Hex with strings varies so much, you pretty much need to supply an example.  The best way is to create a VI with default data in the string control and indicator (to show what you want out).
(4,153 Views)
hi,
   i have a binary no eg :1010 how to do 2's complement of this no
(3,877 Views)
It's good practice that if you have different question start new thread and post.
Anyway this might help: http://digital.ni.com/public.nsf/allkb/57EC3CCB9DA0756786256649006421FF
uday
(3,873 Views)
I saw that link,in that link they are showing binary values by changing the property type of indicator instead of numeric they are showing in binary but I want binary as my output
(3,867 Views)
