convert array to fewer smaples per second
Have large array with 9 channels of data per times stamp.
Timestamp shows that there are about 100 samples per second.
I need to generate array that only displays one average value per channel, per second.
Struggling with "build array" and "indexing" to get proper array.
Suggestions??
(3,016 Views)
Try this Mark
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(3,011 Views)
I might even attach the VI this time!! (V 8.6)
(3,009 Views)
Accepted by markfranklin
Suggestions??
I'd bag the building and indexing and check out the Decimate VIs in the Signal Processing Palette.  Unless you are stuck with the base version.
(2,997 Views)
Never used the decimate, love it, thanks.
(2,971 Views)
Awesome Darin. I've seen it on the pallette but never been able to work out when you would use it, now I can.
(2,959 Views)
