convert array to fewer smaples per second
Have large array with 9 channels of data per times stamp.
Timestamp shows that there are about 100 samples per second.
I need to generate array that only displays one average value per channel, per second.
Struggling with "build array" and "indexing" to get proper array.
Suggestions??
(3,307 Views)
Try this Mark
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,302 Views)
I might even attach the VI this time!! (V 8.6)
(3,300 Views)
Accepted by topic author markfranklin
Suggestions??
I'd bag the building and indexing and check out the Decimate VIs in the Signal Processing Palette.  Unless you are stuck with the base version.
(3,288 Views)
Never used the decimate, love it, thanks.
(3,262 Views)
Awesome Darin. I've seen it on the pallette but never been able to work out when you would use it, now I can.
(3,250 Views)
