convert binary data to scaled data
If I got a binary data from DAQmx Read.VI (Analog 2D I16 Nchan Nsamp), how can I convert this to scaled data?
Best,
Jay
Message 1 of 8
(5,071 Views)
Depends. If you have a new M series board, with it's advanced calibration technique, you have to apply the scaling coefficients. There is are examples called Cont Acq&Graph Voltage-To File(Binary).vi and Graph Acquired Binary Data.vi that show how top obtain the property and how to scale data with the coefficients.
If you are converting to scaled data in your acquisition VI, why acquire as I16?
Message 2 of 8
(5,066 Views)
Dear Dennis,
Thanks for your reply. I have E series board. In this case, I can't ues the property node, can I? Is there any alternate way?
I am acquiring as I16 since I need bouth I16 and scaled data.
Jay
Message 3 of 8
(5,062 Views)
Then it's linear. Get your voltage range, and divide by how many steps you can have (if you have a 12 bit a/d, this 2**12). This is your scaling factor.
Message 4 of 8
(5,057 Views)
Thanks, Dennis.
But could you tell me in detail? I've just started to learn LV recently, so I need your more explanation.
Thanks, again.
Jay
Message 5 of 8
(5,053 Views)
I have a voltage range -5/+5. I'm not sure what you meant by number of steps. I don't know what a/d is.
Jay
Message 6 of 8
(5,045 Views)
Accepted by topic author jeongho20000
See if this makes sense. There's probably a property for the number of bits the A/D has but I can't think of it right now and can't spend toom much time looking.
Message 7 of 8
(5,042 Views)
Thank you so much, Dennis. You save me. 🙂
Best,
Jay
Message 8 of 8
(5,032 Views)
