convert imaq image into image vidéo format
hi,
(i'm using a french version of labview 7.0, so please answer with components in french!!!)
i need to convert an IMAQ image (coming out from an IMAQ-Acquire vi) into the image format that comes out from the following vi:
"Tracer une table de pixels redressé", whic in my case has a 24bit-pixmap in input.
On the help I can't find what image format comes out from "Tracer une table de pixels redressé" and after several essays  I can't find a suitable vi converter.
please help me.
thank you very much
fil
(2,612 Views)
Hi Fil,
Sorry for this late answer. Are you still facing the problem.
I suggest you to check within the examples first.
(2,596 Views)
thank you for the reply
yes i checked but i found nothing special.
actually i have tried to route the imaq-image into a 'createJPEGfil' vi. then i loaded the jpegfile, routed it into a 'redresser table de pixel' and then into 'tracer une table de pixel radressé' which has the output that i needed ('image'  type).  but that's sad, as i'm obliged to access to the hard-disk; saving and loading a jpeg file, hence slowing down the all thing.
any other ideaz?
merci
fil
(2,583 Views)
