04-24-2007 11:04 AM
04-27-2007 11:14 AM
Hi Fil,
Sorry for this late answer. Are you still facing the problem.
I suggest you to check within the examples first.
04-30-2007 04:36 AM
thank you for the reply
yes i checked but i found nothing special.
actually i have tried to route the imaq-image into a 'createJPEGfil' vi. then i loaded the jpegfile, routed it into a 'redresser table de pixel' and then into 'tracer une table de pixel radressé' which has the output that i needed ('image' type). but that's sad, as i'm obliged to access to the hard-disk; saving and loading a jpeg file, hence slowing down the all thing.
any other ideaz?
merci
fil
