11-19-2009 09:23 AM
Can anybody convert this program written in 6.1 version to 7.1.
Is the subvi's required for this.
Solved! Go to Solution.
11-19-2009 10:54 AM
You should be able to just open it up in LV 7.1.
Did you have a problem when you tried?
11-19-2009 10:57 AM
11-19-2009 11:07 AM
When I open the program it shows the following screen.I just want to clarify whether it is version incompatibility.
11-19-2009 11:12 AM
So you have both 6.1 and 7.1 versions installed in the same PC?
Those are just warning messages. But try renaming or save it in a different location.
11-19-2009 11:12 AM
Did you read the messages?!
Basically, the files were loaded from the 7.1 location instead of the 6.1 location. Most likely these third party driver VIs exist in both versions on your computer and LabVIEW was smart enough to load it from the new location after you switched to 7.1. That's probably a good thing! :). Do you get any broken arrows?
11-19-2009 11:17 AM
No broken arrows when I open it. If it is alright I think I can proceed to the next step of the program. Thanks to all.
Posting the task as new post.
11-19-2009 11:18 AM
