convert pulse to latched
Sorry  Dan
I am having trouble getting your diagram implemented.
Here is what i have so far.
Message 11 of 17
(1,436 Views)
Skip the "initialize" control, the values should be the only thing latching and unlatching the signal (I remember what I said).  You should also get rid of that sub-VI between the "or" and the"high" and "low" indicators.
Also, what are "y" and  "y 2"?  Are those the real threshold values?  If so, get rid of the constant (.6 and .3) threshold values, it's getting confusing.
   ...Dan
Message 12 of 17
(1,426 Views)
have cleaned it up like you asked but ihave broken line.
how is it using data and boolean at the same  time?
It looks like that is my problem, eh.I
Message 13 of 17
(1,409 Views)
Can't see it, I'm at LV 7.1.  Anyway, keep it simple, keep the logic as boolean only -- forget the "data"
   ...Dan
Message 14 of 17
(1,394 Views)
This code should also do the trick (I've attached the VI saved in LV 8.6):
Boolean Latch
The case structure that Dan mentioned in post #4 will work as well--just showing another way to implement the latch using boolean logic.
-John
Message Edited by John P on 10-15-2008 11:33 AM
John Passiak
Message 15 of 17
(1,377 Views)
Accepted by mgtyper
I agree, it's a better way than what I had called out -- with the case structure.
  ...Dan
Message 16 of 17
(1,363 Views)
thank you
that worked just fine
Message 17 of 17
(1,301 Views)
