convert string to number
that is good one bilko Smiley Very Happy Smiley Very Happy Smiley Very Happy
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 21 of 35
(1,901 Views)
I have a particular power supply in mind... it even specifies a "typical" time to wait for the power supply to process the last command - sheesh!  😉
Bill
CLD
(Mid-Level minion.)
Message 22 of 35
(1,898 Views)
Looks like you found some device to do R&D with...Great.
--Ranjeet
Message 23 of 35
(1,896 Views)
the function which jcarmody posted was that thing I want, it converts my string to number and I can use that as a numeric variable.. like connecting to Thermometer or chart.. thank you 🙂
to that friend who told I didn't use any delay in while loop: I send the data from microcontroller every second I mean I set my delay in my main code in microcontroller.. is that ok ? 🙂
another question : would you explain how to set the count byte input of read function ? I set that on 4 .. but when the temp. goes above of 100 degree (5 character)
it shows it wrong... any idea ? 🙂
Message 24 of 35
(1,870 Views)
As discussed, the recommendation to use a wait is not correct.
Use some high arbitrary number for a byte count. Your program says to use a termination character (a LF) for the Read. This is set with the VISA Configure Serial Port and means the read will automatically terminate when the character is detected.
Message 25 of 35
(1,868 Views)
Also note that you need your microcontroller to send this termination character in order to have the VISA Read terminate on it.  As already stated, a Line Feed (0xA) is the default for VISA.  Since you are apparently dealing with ASCII characters, that would be a good option.
GCentral
Message 26 of 35
(1,859 Views)
thank you Dennis_Knutson and crossrulz..
would you explain a little more ? you mean I shoud send (0x0A) code after the main data ??
Message 27 of 35
(1,845 Views)
Yes. Program your micro to append the LF at the end. You can use other values but your LabVIEW code is currently programmed to expect that. If its not programmed to send a termination character, I would have expected your program to generate a warning.
Message 28 of 35
(1,839 Views)
I've just select the blocks and put them together and wired them.. I didn't know it would need that. what makes my labview code to expect that ?? Smiley Sad
Message 29 of 35
(1,833 Views)
I applied the 0x0a ascii code after main data .. but It didnt responsed in labview .. the data was swing up and down..
this is my code : Untitled.jpg
and I set the byte count to 10.. the result is like this : 23.123.223 , 24.123.223 ... << 10 characters .. :-??? Smiley Sad
Message 30 of 35
(1,827 Views)
