convert the Triangle average method of VBA code to LabVIEW
Dose anyone know how to convert the Triangle average method of VBA code to LabVIEW? thanks!
Sub triaverage()
startline = 3
endline = 1253 '1253
datacolumn = 3
pointmax = 1251
n = 17
wlresolution = 0.004
myrange = (n - 1) / 2
weightfactor = 1 / ((n - 1) / 2)
pointindex = 0
For i = startline To endline
weightsum = 0
weightedpowersum = 0
pointindex = pointindex + 1 'data point under process
For j = -myrange To 0 'left side including the very point itself
movingpoint = pointindex + j 'moving point in the range
If movingpoint > 0 And movingpoint < pointmax Then
movingweight = 1 + j * weightfactor 'moving weight for each point in the range
weightsum = weightsum + movingweight 'sum up all involved weight
weightedpower = movingweight * Worksheets("sheet1").Cells(i + j, datacolumn)
weightedpowersum = weightedpowersum + weightedpower
'Debug.Print j, movingpoint, movingweight, weightsum, i, weightedpower, weightedpowersum, averagepower
End If
Next j
For j = 1 To myrange 'right side excluding the very point itself
movingweight = 1 - j * weightfactor 'moving weight for each point in the range
End If
Next j
averagepower = weightedpowersum / weightsum
Worksheets("sheet1").Cells(i, datacolumn + 2) = averagepower
'Debug.Print i, weightsum
Next i
Message 1 of 12
(5,561 Views)
Hi ronke,
where are you having problems with?
Basically its a running average over a 1D array of values ("datacolumn")…
Show your VI (or the attempt to create one) and we will help you with your homework!
Cleaning up the VBA code may improve it's readability:
  weightsum = 0
    End If
  Next j
    End If
  Next j
Next i
 A main loop with two FOR loops inside. In each inner FOR loop you will need a case structure…
(The LabVIEW version will look better when you use autoindexing and polymorphism.)
Message 2 of 12
(5,542 Views)
In fact I don't have this vi, just try to create a vi to replace the VBA to integrating this calculation method into LabVIEW, but I'm not familar with VBA, so neet some help to convert this average method to LabVIEW, so I need some help, thanks.
Message 3 of 12
(5,533 Views)
Hi ronke,
most of that code are just variable names, the only VBA-for-Excel specific part are those two Cell calls:
Here a value from your Excel table is read: replace this by an IndexArray function to your 1D array data (or autoindexing).
Message 4 of 12
(5,530 Views)
I try to using the LabVIEW formula node to write this VI, but show some error, Cold you help me provide a VI example for me, many thanks.
Message 5 of 12
(5,527 Views)
GerdW 已写:
Hi ronke,
GerdW 已写:
Hi ronke,
Message 6 of 12
(5,526 Views)
Hi ronke,
Why do you need a formula node?
And which errors do you get?
No. Why should I do your task of doing the programming?
I repeat: Attach your VI (or the attempt to create one) and we will help you to solve your homework!
Message 7 of 12
(5,518 Views)
Attached is the VI example to replace the excel calculation method360软件小助手截图20180126221505 (3).png
Message 8 of 12
(5,516 Views)
Hi ronke,
and where's the part for that running average?
Message 9 of 12
(5,491 Views)
I using the TSA moving average in this VI now, see the yellow label, just plat to using Triangle average method to replace this VI.
Message 10 of 12
(5,488 Views)
