‎03-08-2010 11:42 AM
hi, how can i convert a dbl numbers to a voltage with a Pci 6713. Could somebody help me. Thanks.
‎03-08-2010 11:52 AM
‎03-08-2010 11:55 AM
Your subject says convert a voltage to a dbl but your message body says convert a dbl to a voltage. Since the 6713 is only DAQmx, let's assume the message body is correct.
First, look at the DAQ Getting Started to gain some basic understanding. Then open Help>Find Examples and expand the Hardware Input & Output>DAQmx>Analog Generation and look at all of those examples. They all use a DAQmx Write. You can also use the DAQ Assistant.
‎03-08-2010 12:04 PM
‎03-08-2010 12:08 PM
What?
You could not have had time to read the introduction to DAQmx.
‎03-08-2010 12:11 PM
