convert voltage to dbl
hi, how can i convert a dbl numbers to a voltage with a Pci 6713. Could somebody help me. Thanks.
(3,056 Views)
Hi unai,
use DAQmx functions to control your PCI card. That way you can use the AnalogOutputs in a fairly easy way.
And probably you will find examples in the LV example finder Smiley Wink
(3,050 Views)
Your subject says convert a voltage to a dbl but your message body says convert a dbl to a voltage. Since the 6713 is only DAQmx, let's assume the message body is correct.
First, look at the DAQ Getting Started to gain some basic understanding. Then open Help>Find Examples and expand the Hardware Input & Output>DAQmx>Analog Generation and look at all of those examples. They all use a DAQmx Write. You can also use the DAQ Assistant.
(3,047 Views)
thanks but could you tell me what type of data send this kind of pci
(3,043 Views)
What?
You could not have had time to read the introduction to DAQmx.
(3,038 Views)
Hi unai,
your PCI-6713 is an AnalogOutput card and independent from the datatype you use...
Please read the manual, look at the examples and take the free online course to get an introduction to LV!
(3,034 Views)
