converting 4 bytes to float
Wow, I must be onest. I didn't expect solving of my problem so fast.
Many thanks to crossrulz. His vi works 100% correct.
Regards to all!
Vlado
Message 11 of 15
(4,217 Views)
Back again.
This time I need help with oposite conversion from float to 4 byte array.
It should be used Microchip conversion where from MSB side eight bits are used for exponent, then one bit for sign and rest of 23 bits for mantissa.
So question, how to modify attached example to get desired result?
Regards, Vlado
Message 12 of 15
(4,128 Views)
Accepted by topic author California_J
California_J wrote:  This time I need help with oposite conversion from float to 4 byte array.
All you actually have to do is change the Rotate Left on the MSB to a Rotate Right.
Message 13 of 15
(4,108 Views)
Here you go.
Message 14 of 15
(3,451 Views)
@davekorpi wrote:
How did you figure that out??
It's called a snippet.
Message 15 of 15
(3,434 Views)
