converting PID example
Hello again.
I finally got back on this project. I am to create a testsetup for students to work on. The simulation example PID does almost exactly what we want it to do. So now I would like to convert the simulation to work with my NI9203 and NI9265. However my experience with programming and labview and processcontrol is very limited. And I have no idea how to redo the VI to include those DAQ's.
The idea behind the setup is to give the students a setup that will allow them to see the differences and effects of a P, PI and PID controled watertank in wich the level can be adjusted by controlling the valvesetting in the inlet pipe.
My setup is build with the following components:
- pneumatic valve controlled by NI-9265
- level indicator controlled by NI-9203
- Labview 2010
- PID and Fuzzylogic toolkit
Kind regards
Ivo
(2,841 Views)
Hallo Ivo,
After reading your question I have to say that I need more info about your setup.
First of all I need to know which chassis do you use. cRIO, DAQ,...
Then I can help you further more.
(2,767 Views)
