Can't see my RS232 ports on my NI DAQ 6501.
Hi All,
I've got a NI DAQ 6501 working well.. However, now I would like to use the serial port capability on the DAQ 6501. I double-checked the software installation in MAX, and I do have Visa & NI-Serial installed. When I look at the cFP-2120 in Max, I see the LED's, some assorted inputs, dipswitches, but not one of the  serial ports.is working.
Can you please suggest in this regard.
Sandhya
(2,843 Views)
Accepted by topic author Emsys Techie
I think you may be a bit confused about the capabilities of the 6501.  It's a digital I/O device that connects over USB.  I don't think it has anything to do with RS-232.
(2,837 Views)
On the other hand, your 2120 has 3 RS-232 and 1 RS-485.  Post your code for those and someone here can probably help you out.
(2,835 Views)
Serial ports on the cFP-2120 will not appear in MAX.  The reason is that none of the cFP controllers are capable of running NI-VISA Server.
(2,832 Views)
