converting a group of 1-D arrays to one 2-D array.
I want to build a 2-D array out of multiple 1-D arrays so that I can wire the 2-D array to the "Write to Spreadsheet File.vi" function. I searched the Array palette endlessly with no luck...any ideas?
(2,754 Views)
Hi Yusif
Search for the "Build Array" function in the Array palette. The "Build Array" concatenates multiple arrays or appends elements to an n-dimensional array.
Luca P.
Application Engineer
Luca
(2,754 Views)
AS Luca suggested the buid array will increase the dimension of your data type by 1-d.
I believe there is anoher input to the "Write to ..." that accepts a 1-d input.
Ben
(2,754 Views)
