converting .vi to an executable
I'm a little new to LabVIEW and programming in general.
I've written my first LabVIEW program ( single VI-Lab View 2015) controlling instrumentation.
I now want to be able to run this single .vi as an executable.
After I do this -be able to run this program on an independent computer that only has national instruments max Explorer with the driver GPIB-USB-HS?
So if the answer to the previous question is yes, then could somebody give me the step-by-step procedure to convert my single VI to the executable?
Thank you
Message 1 of 13
(7,221 Views)
You need to do this.
You will be prompted to make a project. Don't forget you will need the runtime engine to run this exe on a different computer. That is an additional program for NI Max.
Tim
GHSP
Message 2 of 13
(7,206 Views)
Note, the application builder is a separate purchase from just the core LabVIEW; follow this link if you don't have it installed.
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
Also, after you build an executable, i'd recommend you build an installer.  This will allow you to include the drivers with the executable.
Message 3 of 13
(7,173 Views)
thank you very much for the reply,
I'd like to ask one or two more basic questions because I'm still a little bit confused..
I was under the hopeful impression that I could convert a LabVIEW VI into an executable run only standalone program,
without purchasing the LabVIEW runtime engine?
Any clarification of this would be very helpful, thank you.
Message 4 of 13
(6,772 Views)
You need to purchase (or have) the Application Builder Addon to make an exe and installer. The LabVIEW Runtime Engine is free to distribute, but somewhat useless without a LabVIEW app.
mcduff
Message 5 of 13
(6,766 Views)
okay.. I get it now thank you very much for your help
Message 6 of 13
(6,760 Views)
Your development machine already has the run-time engine installed, so if you build an installer from your exe, you can include both the run-time engine and the drivers you need (simplifies putting your app on new machines).  You can also include other things, like documentation to go with your app.
Message 7 of 13
(6,754 Views)
thank you
Message 8 of 13
(6,737 Views)
Once again thank you for your help,
Next line of questioning- so I'm able to create a run time version of my program and I am able to download and install the 2015 LabVIEW runtime engine. This is all going on on the same computer that I have the developmental version of LabVIEW.
What I haven't been able to clearly see  is how to do this on the run time only program with a computer that doesn't have the developmental version of LabVIEW on it?
On the second computer I have installed a couple versions of the runtime engine in order to match the executable version that I'm trying to run.
I
I get the error can't find the runtime engine when I tried to click on the executable.
So a little more detail on exactly how to run an executable from a computer that doesn't have LabVIEW developmental version.
Thank you
Chris
Message 9 of 13
(6,666 Views)
as previously mentioned you should build an installer for your application.  In the "additional installers" section, make sure the run-time engine is selected.  If your deployment machine still gives you errors after you run the installer, there is a chance one of the other run-time engine has a corrupted file.  clean the computer of all NI software and re-run your installer.
Message 10 of 13
(6,659 Views)
