how to determine if your circuit will not work?
i design a power supply circuit with a voltage regulator and a variable resistor..why is that its ohm measurement reaches Gohm and the voltage output works fine...
(2,383 Views)
Where does LabVIEW fit into this question?
Are any National Instruments Data Acquisition products used in the measurements?
So far your question sounds like it belongs on a electrical design forum.
(2,371 Views)
Are you asking about a physical circuit? You do realize this is a software forum right?
Tim
GHSP
(2,369 Views)
Is this a multisim or a hardware question?
(As others have already said, this does not look like a LabVIEW questions.)
(2,340 Views)
