09-26-2007 06:35 AM
09-26-2007 11:14 AM
To get the Y array (DBL) of a waveform, you just use "get waveforms components" and select the Y output.
(For more detailed help, could you make a small demo VI that only shows the problem issue.)
09-27-2007 02:18 AM
09-27-2007 02:27 AM
Shashank,
As Altenbach had already suggested, please post the problamatic portion of the code.
Also, mention the version of LV you re using...
We assume that it may be 8.x up because of 64-bit nos.
I dont ve any experience regarding Transfer Functions, so I cant tell you anything.
09-27-2007 02:42 AM
If the source is an array of waveforms, place a FOR loop around the "get waveform components".
Still, I am not sure whay you even have an array of waveforms, because you only simulate a single square wave on the left. When you convert the dynamic data, you have a choice to either convert it to a 1D array of waveforms or to a single waveform. Since you don't include any of the subVIs that operate on it, it is not clear what you actually need.
Please isulate the problem code into a small example VI and post it.
09-27-2007 02:44 AM
I think he means DBL, which was always available. 🙂
@parthabe wrote:
We assume that it may be 8.x up because of 64-bit nos.![]()
09-27-2007 03:42 AM
09-27-2007 03:52 AM
Yes, now-a-days I forget to see the wire's help.
Thank you, Sir!
09-27-2007 07:32 AM - edited 09-27-2007 07:32 AM
Message Edited by altenbach on 09-27-2007 05:35 AM
09-27-2007 07:48 AM
