conveyor counting
I have made a labview program about counting random numbers 1-10 that appear, how can I make it so that when a number appears 2 times it will be entered into an array based on groups, for example 1 (A), 2 (B), 3 (C) and so on, not only when 2 times appear but every multiple of 2, such as 4 times appearing 6 times and so on.
Message 11 of 16
(1,017 Views)
Hi rahiltzy,
@rahiltzy wrote:
I have made a labview program about counting random numbers …
But you still failed to attach it…
By implementing the needed algorithm in LabVIEW!
Can you describe the required algorithm with words?
Message 12 of 16
(1,010 Views)
how to implement node analysis formula to calculate resistor voltage into labview
Message 13 of 16
(973 Views)
Hi rahiltzy,
Please explain "node analysis formula": which kind of formula do you talk about?
What is a "resistor voltage"? All the resistors I heard of only have a resistance…
Message 14 of 16
(961 Views)
 yees, resistance voltage
Message 15 of 16
(947 Views)
Hi rahiltzy,
I see 4 resistors and two power supplies, but still don't know about "resistance voltage"…
Do you need help in applying basic knowledge like those Kirchhoff rules?
Message 16 of 16
(941 Views)
