convolution encoding.decoding
   Hi
  i am working with covnvolution encoder/decoder in labview. I have a questrion i.e when i ammend generator matrix using 7/8 rate encoder/decoder it gives erros with the same Generator Matrix provided to the encoder/decoder..Rest rates are working fine(6/7,5/6 etc) Can any one explain this to me why i have error
Regards
(3,058 Views)
hi,
can you elaborate your question so tha i can help.
Also, if you attach your vi or code snippet will be helpfull in solving the problem.
regards,
Yogesh
(3,046 Views)
