convolution vi
Just as an additional note, maybe saving you some time in your next project.
Let's look at the code you have posted:
  • index array is resizeable.
  • No need for dynamic data
  • etc.
Here's how identical code would look like cleaned up.
Message 11 of 14
(2,560 Views)
I am so sorry. I thoought that I have understood what you said, but I do not!Smiley Sad
Can you please give more details (or vi) about this:  "take the subset from 25% to 75% of the output size to get the scaling correctly"
Message 12 of 14
(2,546 Views)
Here's a quick example:
If the inputs are 1024 points, the output will be 2048 points. You need to take the subset starting with 512 and lenght 1024.
Message 13 of 14
(2,531 Views)
Very helpful. Thank you so much.
Message 14 of 14
(2,487 Views)
