convolutional interleaver
Hi all,
I had posted a query on using arrays to implement shift register for implementing convolutional interleaver few days ago. The question was not clear enough and then when I understood it, I was able to implement it on my on. ( http://forums.ni.com/t5/LabVIEW/Implementation-of-shift-register-using-array/td-p/1772302 )
Here, I have attached the VI's that I came up with. But the design is fixed for 4 channels. If there are 100's of channels, I can't use this VI.
So, I want to design a generic VI which should be able to perform interleaving for any number of channels.
For this, single buffer(array) should be used instead of separate array for each channel if I am not wrong. I am working on it.
Please help me out in implementing this.
Thank you.
(4,741 Views)
It's interesting to note that all the complex code in your example can be replaced with a pair of array index/array build functions.Interleave.jpg
I wouldn't normally recommend doing it this way, but it is the most direct method for four channels... and helps to illustrate exactly what you're trying to do.
Having done that, I can see clearly that  you want to build one array from another, with the indexes shifted as such;
0, 0, 0, 0, 4, 1, 0, 0, 8, 5, 2, 0, 12, 9, 6, 3, 16, 13, 10, 7, 20, 17, 14, 11...
(I put some zeros in red to indicate that they are the value zero, not the index zero.)
This follows these rules:
  • If I (index of result) is divisible by 4, use i (index of input)
  • If I/4 has remainder =1, use i-4
  • if I/4 has remainder =2, use i-8
  • if I/4 has remainder =3, use i-12
Or, to put it more concisely: use I=i-4*iREM4
The attached vi will accomplish this, for N=4.
if you want to use more than 4 channels, just change the 4 constant to whatever you want it to be.
(4,727 Views)
This version here will give you accss to both the Interleaved output data and also the data of any specific channel.
(4,721 Views)
That was indeed very helpful LandBelenky.
Thanks a lot. You were kind to explain in detail too 🙂
I designed the de-interleaver by tweaking the interleaver design a bit. And here is the final implementation.
(4,707 Views)
(4,584 Views)
Hello, I'm trying to implement a convolutional interleaver for more than 2 blocks. Please find this attached. But I don't get the correct output. for the 1st interation I get 0 0 0 0 4 1 0 0 8 5 2 0... and after the second iteration I get 12 0 0 0 16 13 0 0 20 17 14 0 0. But I want this to be continous i.e, 0 0 0 0 4 1 0 0 8 5 2 0 12 9 6 3 and so on. I think the proble is with your code the values that are not used aren't being stored. Can you please help? Thank you
(4,577 Views)
