copying calibration data
Is it possible to copy the claibration data from Vi to another, or from one DAQ Assistant to another? I have calibrated pressure sensors in seperate Vi's and now wish to create a combined one. Whilst the scales carry over the calibrations do not. However there is no way of inserting the calibration data, short of getting a voltage generator and recreating all the voltages. Is using the scale by table a reasonable alternative?
(3,089 Views)
You can write calibration data in the temp file or LV2G.
then use this data to combine with the other data.
Or else you can create a scale. this will help you to update data
https://decibel.ni.com/content/docs/DOC-23044
Regards
Prabhakant Patil
(3,087 Views)
bello / above link might help you
Regards
Prabhakant Patil
(3,085 Views)
The problem with just writting the calibration data to a scale is that labview then interpolates between the points provided to find other values. This is not neccessarily accurate as the sensor has a mainly linear characteristics but was calibrated due to non-linearities at the extremes of it ranges. So i could add extra values between the calibration values that fit the linear model. However i don't know the algorithms used with the calibration function within DAQ Assistant and so cannot recreate the shape which i know to be correct.
(3,081 Views)
Accepted by topic author NPSell
If you press pause within the calibrate tool you can edit the input value as well as the reference and then commit both, so problem solved.
(3,079 Views)
