correctly wired servo returning unknown error
hey, I'm trying to get a servo to rotate 20 degrees but I just keep getting this error.
I check and it looks like I'm initializing and calling it correctly.
(1,663 Views)
also it doesn't work on multiple relays and we used the example code and that doesn't work.
(1,646 Views)
It is probably your Hardware or your Software.  Since you have not attached your Software (meaning all of the LabVIEW code you are using, not pictures of code, but the actual VIs, or a compressed Project) nor any information to inform us about the hardware (and wiring) you are using, I recommend you hire a consultant with LabVIEW expertise.  [Or provide more information so we can help you ...].
(1,604 Views)
