could not be uploaded to file LIFA_Base
I have trouble when I tried to upload a file lifa_base and error,,,
I am still a beginner and want to learn how to make the lab view interact with arduino, I hope no one is willing to help me, to which I reply thank a lot .
buat yang tau masalahnya ini kenapa mohon pencerahannya, maklum saya pemula sekali 😄
(3,364 Views)
You should have seen that LIFA is no longer supported. Try LINX - https://decibel.ni.com/content/groups/labview-interface-for-arduino
(3,358 Views)
well I will try and tell you the results , Thanks to the solution
(3,353 Views)
yes, it does work 😄
(3,345 Views)
how did you manage to get it work
(3,237 Views)
