excel freeze panes
Hi
I'm using ActiveX to create an excel spreadsheet and fill it with data. Is it possible to use the excel freeze panes command from Labview and if so how ? I want to keep the column/row headings in sight so I was hoping to use freeze panes which I could setup straight after the wroksheet is created. Anyone got any ideas?
Cheers
Dave
Message 1 of 10
(11,157 Views)
Hi Dave,
have a look at the attachment
My LabVIEW Ideas
Message 2 of 10
(11,151 Views)
In addition a great way to discover such things is to create a Macro with Excel, read it's code and try to rebuild it with LabVIEW. But be prepared to deep dig in ActiveX and the report generation toolkit!
Ton
PS you need to have the toolkit to run my previous VI!!!!
My LabVIEW Ideas
Message 3 of 10
(11,150 Views)
All I can say is WOW!!!
Message 4 of 10
(11,144 Views)
Hi Ton
Thanks for that.
I'm running 7.1 and can't seem to get the Vi to work in the same way as excel does it. I can freeze the panes, but it introduces a big heavy grey bar in which the contents can be scrolled. I just want to highlight a couple of columns and rows and freeze them. In Excel this produces a thin black line  and panes that cannot be scrolled.
Cheers
Dave
Message 5 of 10
(11,119 Views)
Hi Dave
Try this. Its not pretty but hopefully it will work for you. Its based on the shipped example Write Table To Excel so it might be an idea to add the examples directory to your VI Search path so that it picks up the right stuff.
David
Message 6 of 10
(11,107 Views)
Hi Dave,
i think you missed the true boolean connected to the split method, this creates the option that you want!
Good luck,
Ton
My LabVIEW Ideas
Message 7 of 10
(11,090 Views)
Hi David
Thanks for that, now working perfectly.
Cheers
Dave
Message 8 of 10
(11,074 Views)
Hello, David
what include in the subVI "Row Col To Range Format.vi"?
Eli
"I think therefore I am"
Message 9 of 10
(6,765 Views)
Dear Eli,
     You are posting a followup to discussions almost a decade old!  Consider starting a New Message and asking your own questions.  Among other changes since LabVIEW 7 is the Report Generation Toolkit has been vastly improved (it now uses Report Objects, very cool), making it possible to do a lot of things with Excel Workbooks without ever needing to use ActiveX (and it is pretty fast, as well).
Bob Schor
Message 10 of 10
(6,723 Views)
