could not release vi to web with BlockedPlugin
Hi ,
  i imitate an example of Labvew ,release VI to web,aftter i copy URL to web address, VI could not be uploaded to web, and it has an information ,
i cut the screen as follow, and i have changed web browser, such as IE,Microsoft Edge,Google chrome,
i want to know how to solve this issue, do i need to edit configuration of web browser?
thank you for your response!
                xiaoxu
(1,419 Views)
Hello xiaoxu0411
Using the supported browser (Internet Explorer) can be the solution to the issue. If there are concerns about Internet Explorer not being supported on certain versions of Windows 10 starting June 15, 2022. A valid workaround is to use the Microsoft Edge Browser on Internet Explorer Mode .
For more information go through this article
Regards)
______________________________________________
Best way to thank is giving a Kudos/Marking as a solution
(1,361 Views)
Yes, copy URL to IE tursted zone, it shows correctly. i install LABVIEW to the third PC, and i will try ro release to another PC not installed labvew, i browsed from website, my understanding is intall run engine is enough
(1,000 Views)
