could someone explain the select comparison
Right below the message body is 'Add Attachments'. Click on it. You'll then get a browse button.
Message 11 of 16
(1,499 Views)
Thanks. This is what I have so far but I don't know what I am supposed to put in the T and F terminals.
Message 12 of 16
(1,497 Views)
Accepted by Laudie3a
The T and F terminals will accept any data type as long as they are both the same. You would choose a data type to match whatever you want to connect the output to. In other words, the T, F, and output have to be the same data types. Since you know what you want to connect to, you should now know what the inputs should be.
Message 13 of 16
(1,491 Views)
Ok. But I want the output to be the LED so that would mean the inputs would have to be a boolean as well and according to the picture that is not the case.
Message 14 of 16
(1,486 Views)
The select comparison is like a gate.  If the condition is True, then pass through whatever is in the True input to the output of the function.  If the condition is False, then pass through whatever is wired to the False input to the output of the function.  It could be a datatype of any kind, a number, a string, a boolean.  Since you want the output to be a boolean, then you wire a boolean to the True input and a boolean to the False output.
However, in its simplest form, it is a ridiculous construction and is highlighted in an early post in the Rube Goldberg thread here.
Message 15 of 16
(1,484 Views)
Thank you everyone for your help! I got it and I think I understand now! I didn't realize there were boolean expressions as well!
Message 16 of 16
(1,481 Views)
