count number pixcel labview vision 2013
hi gays
i need your help i want to count number of pixel with template in labview vison 2013
thanks
(3,312 Views)
What pixels, and what templates are you talking about?
Provide some information in your question.  Perhaps attach a VI or at leaste a picture of what you want.
(3,286 Views)
i want determines the precentage of pixels in a region of intreset that have a given intensity range
like the the finction count pixels in NI vision builder AI but i want in labview vision 2013
thanks
(3,261 Views)
Accepted by topic author dalyto
Try the VI IMAQ Count Objects 2 in the Vision And Motion>Machine Vision>Count and Measure Objects palette.
If that does not do exactly what you want, you can still choose to migrate the VBAI inspection to LabVIEW (Tools>>Migrate Inspection to LabVIEW from VBAI) and look at the code generated. It will produce exactly the same results as in VBAI. The only thing is that the code generated is complex.
Hope this helps.
Christophe
(3,203 Views)
 hi ChristopheC
thanks for help
(3,184 Views)
