count pixel
Hello all ,
i need to find the percentage of Pixels and number of pixels in intensity range  in LabVIEW only . as like the "count pixel " function in the NI VISION BUILDER AI .
i tried with the Imaq histogram and imaq get pixel value . pls suggest me a options .
(4,253 Views)
Do you have Vision Acquisition Software? You can use IMAQ image to array to get the pixel intensities.
(4,193 Views)
a way without vision...
(4,182 Views)
Hi zwired1,
May i know, for what purpose you gave an intensity range from 200 to 256 ?
(4,169 Views)
Just random numbers as placeholders.  You will need to put in numbers that suit your application.
In greyscale 0 is black and 255 is white so the range I put it would count "relatively bright" pixels.
(4,157 Views)
