counter program? Like a ticker
I need to make a program that keeps count, whether i press a "minus 1" button or a "plus 1" button in the while loop. I'm not sure on how to actually convert the boolean logic of the button pressed to equal an addition of the number? Any comments appreciated!
Message 1 of 12
(6,007 Views)
Message 2 of 12
(5,998 Views)
Mathan, were both of your buttons supposed to increment it? Or did you forget a case?
Is there any reason you don't want to use a simple numeric since you want to increase and decrease it manually?
The up and down buttons are your plus 1 and minus 1 buttons with no booleans or logic..
Message Edited by elset191 on 11-12-2009 10:17 AM
Tim Elsey
Certified LabVIEW Architect
Message 3 of 12
(5,995 Views)
That is perfect! thanks Mathan
Message 4 of 12
(5,989 Views)
Accepted by topic author bawhite8
This one actually works. Just messing with you Mathan but yours only counts up.
Tim
GHSP
Message 5 of 12
(5,986 Views)
If you again read the OP's post, he just want to count when the buttons are pressed and not want to actually inc/dec.
Message 6 of 12
(5,977 Views)
aeastet, my version of LabView is to current or too old, can you snap a screen shot of the VI false/true part?
Message 7 of 12
(5,976 Views)
I'm sorry, should have clarified, but I do want the count to increase or decrease according to the +/- buttons pressed continuously
Message 8 of 12
(5,975 Views)
here are the screen shots.
Tim
GHSP
Message 9 of 12
(5,964 Views)
What version of LabVIEW you are using? Here is his program in 8.6.
Message 10 of 12
(5,961 Views)
