seperate x and y values from lvm file
I feel as this should be very simple, but as a novice...
I have recorded 3 data sets into an LVM file, along with the time column at the left.  All I really want to do is put each column into its own array, so that I can build an XY Graph.
Currently, I am using the Read From Measurment File vi, and a build array with a feedback node to build the arrays.  I think I am just stumbling on the data types, and I am not sure how to go about this.  Also I keep running into the end of file error, and could use a tip on how to avoid that.
I will be using this VI to analyze several different sets of data, so I would like to "Load" a data set into the graph, then examine it at will.
Attached are what I have most recently tried, and the LVM file I am trying to read from.
(3,210 Views)
Accepted by topic author krwlz101
This works.
Tim
GHSP
(3,206 Views)
Perfect, thank you.  Now I just need to learn the logic behind what you did.
(3,199 Views)
Here is the breakdown.
Tim
GHSP
(3,195 Views)
