counter
hello
i have the next code in labview which generates a random number between 0-100, i would like to do a counter which count each time that the random number is >50, but i don´t know how increase the times,i just see 1 when this happen,but if i have a new number >50 the counter is still 1, how could i increase the times that random number is >50?   the case false is the same but i add +0, not +1 as true case
thanks
Message 1 of 10
(5,217 Views)
You have the right idea with the shift register. But the shift register needs to be on the outer while loop. Connect the wire through the case structure in the false case. You don't need the inner for loop since it only executes one time. Also it is an initialized shift register since you have the zero wired to the left side. The result will always be 0+1. (Note, there is an increment function that you could use instead of adding 1)
LabVIEW 2012
Message 2 of 10
(5,211 Views)
sorry,i don´t understand what do you want to say with this: the shift register needs to be on the outer while loop?
Message 3 of 10
(5,207 Views)
Feedback as counter
Some times the feedback node can give a clean implementation since you do not have to pass the wires across the entire block diagram.  Also the feedback node has a conditional terminal and initializer in place.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 10
(5,206 Views)
for example if i generate 10 random numbers,and there are 6 values >50 i want to see 6 in the output, but i just see 1
i want to accumulate the true case
Message 5 of 10
(5,203 Views)
Accepted by mariomoskis
You can use a feedback node. That is a good way to do it but those can seem confusing to new users. They really are not complex but with inputs on the right it can seem strange.
See this example. The first loop shows what I was talking about with the shift register and case structure. You can also use the select function as shown in the second loop.
[Edit: I attached another method of incrementing using the bool to 0,1 function.
LabVIEW 2012
Message 6 of 10
(5,201 Views)
Thanks!!! it works well
Message 7 of 10
(5,188 Views)
I have tried both of the recommended schematics and I still get 0 and 1. Can anyone help me out. Maybe I am using a wrong function but I am not sure why it is not working properly.
Juan
Message 8 of 10
(5,022 Views)
jrod-
You have not tried the recommended schematics as they contain shift registers and your code does not. It is not the same code.
Read up about shift registers. Any introductory course explains them.
Message 9 of 10
(5,011 Views)
Thank you for the help, I understand what I did wrong. thanks again
Juan
Message 10 of 10
(4,994 Views)
