crash web publishing tool
Hallo
I have created a program in labview 2010 that read out a DAQ module.  This program should be remote controlled by a website, so I used the web publishing tool from labview and created a website.  When I run the VI it works fine, but when I go to the website to view the frontpanel, the program crashed and turns all windows of labview off.
This problem doesn't happen when I go to the website on the PC that runs the VI, only with other PC.
All the PC I tried have the newest version of labview run time engine, so that isn't the problem.
When I restart labview there I get a error message.  The error is a "Fatal internal error fpsane.cpp line 442- can't find the insane object, even with heep peek window"
Does anyone has a solution for this problem?
Jochem
Message 1 of 1
(2,579 Views)
