crashing exe - requested imd input
Dear All ,
Please check it out the attachment ,
my .exe is getting crased sometime when its running or sometime when iam closing the application .
please pass your valid inputs
(3,978 Views)
ramji hello!
What version of LabVIEW are you using? What version of LabVIEW DSC are you using? What does your application entail? When you run the VI, do you get a similar error? Is there any authorization process embedded in your application? (Essentially do users have to log in and out? It looks like there is a faulty log in as far as the txt file you posted.)
Answers to these questions will definitely be helpful to us in order to help as there might be updates you need to install depending on what version you have.
Please keep us posted!
Efosa O.
NIAE
(3,943 Views)
Hi Efosa ,
What version of LabVIEW are you using? LV7.1
What version of LabVIEW DSC are you using? 6.1
no iam not getting error when iam running as a vi.
i have posted the log file which i received imdly .
there is nothing like log in or log out ,  similar functionality ( login , log out ) iam doing from another vi and transfering the data to my main vi for further action .
Ramji
(3,934 Views)
ramji, how are things?
I am a little confused. How are you using LabVIEW 7.1 with LabVIEW DSC 6.1. That is not possible. Your LabVIEW development system version should be the same as your LabVIEW module version. Please verify that you are using the same versions for both.
The error is very ambiguous and will be hard to troubleshoot if we do not have more information. For example, what does your application entail. Do you have the LabVIEW DSC Runtime. You will need this if you are creating executables with LabVIEW DSC.
However, please first make sure the version of LabVIEW DSC you are using corresponds with your LabVIEW development system.
Efosa O.
NIAE
(3,923 Views)
Iam sorry ,
i was using LV dsc module 7.1 .
This error has occured in Server . Server has no developement system , only DSC run time and only.exe will be running in the server .
Ramji
(3,914 Views)
In the case of the engine error message, the system is not finding the user who is logging in.  Did you either move your lookout.sec file from the development system or create a new one, via the user account manager, on the server machine?  I cannot tell from the jpg what the application error is.
Robert
(3,899 Views)
