crc
I`m struggling with CRC-8 calculation.
I need to make a VI out of picture  crc-8
When I`m trying with just 1 byte on datainput
it`s ok, but with 2-4 bytes it gives me wrong checksum.
Any ideas how to make this Vi work ok?
Thanks for any help,
(7,775 Views)
You should have done some searching.  There are plenty of examples.  I posted this zip package that is actually based off the that exact website's javascript.
(7,765 Views)
Thanks for Your reply.
Even with Your CRC-8 check i do not get same result.
I get value C2  with same input as above but i need 13 as result.
Something i missed out?
(7,731 Views)
Change CRC Calculation from CRC-8 to Other (specify).  The CRC Parameters cluster is only valid when you specify Other.  The CRC-8 is a built-in version which uses an initial value of 0x00.  You also need to set CRC order to 8.
(7,724 Views)
Accepted by Dustyboy
Got it now 🙂
Thanks a lot!
(7,715 Views)
You should mark Matthew's message as the solution to your question rather than your own thank you message.  You can unmark your message by going to the options menu to the upper right of your message.
(7,708 Views)
根据这个帖子,问题得到解决了~谢谢!
(5,208 Views)
