crc8
 I use labview8.5, and I would like to make a program to calculate the CRC8.
Can you help me please
cordially
manu23
Message 1 of 17
(8,280 Views)
Hi manu,
search the forum, CRC calculations are rather common in here!
Message 2 of 17
(8,275 Views)
Did you search the forums for crc8?  If you had you might have found this .
Message 3 of 17
(8,269 Views)
And please don't duplicate you post, or at least say so if you do.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 4 of 17
(8,266 Views)
Yes I looked, but I can not open it because I do not have the right version of labview
Message 5 of 17
(8,263 Views)
Hi manu,
then you should post in the "Version conversion" board!
Message 6 of 17
(8,258 Views)
Then you can ask for someone to "save for previsou version" there is a section for that. Post a link to the VI you would like to be down-converted and the LV version you have 😉
Epictetus
Antoine Chalons
Message 7 of 17
(8,256 Views)
I duplicate my post, because the english forum is more reactive
Message 8 of 17
(8,253 Views)
OK, that's a good reason, but next time give the link to the orginal post in the new one.
Epictetus
Antoine Chalons
Message 9 of 17
(8,250 Views)
Out of curiosity why are you using a CRC8? It is a very weak CRC and you have a 1 in 255 chance of not detecting an error because multiple bit patterns will result in the same CRC. Even a CRC16 is fairly weak.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 17
(8,228 Views)
