create 2D array
FOR loop to autoindex on the array of clusters.  Unbundle the array in the cluster and use Build Array to add a -1 to the end.  While adding on the -1, add the array to the building array.
Message 11 of 16
(1,389 Views)
Now you get a -1 as the very last element, not exactly the same as the original input, but probably close enough. 😄
Message 12 of 16
(1,384 Views)
That's your mistake.  The OP had a -1 at the end of the original array.
Message 13 of 16
(1,381 Views)
You're right, but I was talking about the actual snippet. If there is a guaranteed -1 as last element, my code can be further simplified, i think.... (we don't need the code after the loop, for example)
Message 14 of 16
(1,378 Views)
Accepted by sonotk
If the last element is always -1, we can do the following (also assuming we have LabVIEW 2012 and concatenating output tunnels ;))
Message 15 of 16
(1,366 Views)
Thanks all for the code and explanation.
Message 16 of 16
(1,355 Views)
