create VI for callback reference
hi
I'm first using callback events nodes. It's clear for me but I wander if there is a way to automatically create the VI whose wiring pattern is in accordance with the required vi reference that must be connected to the node (like when creating dynamic dispatch VIs)? or do I have to create it manually?
thanks in advance
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(2,946 Views)
Accepted by Pierre_F
If memory serves, you can r-click the input and select "create callback VI". That should create a VI with the correct connector pattern.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,934 Views)
thanks for the help
(2,905 Views)
